mugatu913's avatar
Nov 30, 2021
ORBI RBR750 - Selective Connectivity Issue for Iphone 12
Ive got the ORBI RBR750 and within the last 2 months my iPhone 12 and my wife's iPhone 12 will not connect to the Internet via the main node. All other wireless devices connect to it just fine, and o...
  • FURRYe38's avatar
    Nov 30, 2021
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling WMM and set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
