mugatu913
Nov 30, 2021Tutor
ORBI RBR750 - Selective Connectivity Issue for Iphone 12
Ive got the ORBI RBR750 and within the last 2 months my iPhone 12 and my wife's iPhone 12 will not connect to the Internet via the main node. All other wireless devices connect to it just fine, and o...
- Nov 30, 2021
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling WMM and set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
mugatu913
Dec 09, 2021Tutor
Thans for your help!
I already had Auto/48 for 2.4/5Ghz and I didn't mess with the channels.
WMM was already enabled, but the 5Ghz CTS was a low number. I set it to 2347 as you recommended and Internet on my iPhone appears to be working now.
You rock. Have a Merry Christmas!
Dec 09, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- mugatu913Dec 09, 2021Tutor
OK, it looked like it was working but now its not working again. It seems like when the iPhone is connected to the main router, the Internet is still getting throttled to 1Mbps/s. When I connect via a satellite, it will run at 750 Mbps. I think I'm still having the problem.
- FURRYe38Dec 09, 2021Guru - Experienced User
Are you sure the phone IS connected to the RBR and not the RBS?
Turn OFF the RBS. Check the speed again with the phone about 10 feet from the RBR.
