brianguy
Nov 02, 2020Star
Orbi RBR750 - webpages and iPhone Apps don't load
I've been reading through several posts in this forum around this same issue, and have not had any luck fixing our at home network. We have the Orbi RBR750, and have the Netgear Nighthawk CM1100 D...
Nov 02, 2020Guru - Experienced User
Ok, Seen odd problems steming from the use of Armor. Try this, disable Armor in the app. Once the app reports it disabled. Power cycle the RBR then test for these problems. If your still seeing problems, I recommend a factory reset of the RBR and setup from scratch, this time do NOT enable Armor.
