brianguy
Nov 02, 2020Star
Orbi RBR750 - webpages and iPhone Apps don't load
I've been reading through several posts in this forum around this same issue, and have not had any luck fixing our at home network. We have the Orbi RBR750, and have the Netgear Nighthawk CM1100 D...
Nov 04, 2020Guru - Experienced User
Turn OFF all RBS and test these two problems with just the RBR running alone...same thing still happen?
Then turn on 1 RBS and test again...
brianguy
Nov 04, 2020Star
Ok just tried disconnecting the satellites and that didn’t seem to help. Initial sense was that it actually make it worse.
- FURRYe38Nov 04, 2020Guru - Experienced User
Is the RBR power out put levels at 100% or lower?
You might try to reload FW using a wired PC and web browser thru the RBRs web page. Factory reset and setup from scratch.
If this still doesn't seem to help any, I would open up a support ticket with NG and check on an RMA...
- brianguyNov 06, 2020Star
Yes, they are both 100%.
I will attempt the hard resent along with the hardwire install of the FM this weekend.
