RosieA
Jun 21, 2022Aspirant
Orbi RBR750 / AX4200 - Need Desktop App to Manage it
I finally got this darn thing to connect to internet. I had an old Netgear router and used the Genie app on desktop, and it works with Orbi ONLY to a point. Can I use another app, maybe Nightwawk, ...
Jun 21, 2022Guru - Experienced User
Use WPA2-AES which is most compatible. Not every device is WPA3 compatible. Especially older devices. There is no WPA6.
RosieA wrote:
I finally got this darn thing to connect to internet. I had an old Netgear router and used the Genie app on desktop, and it works with Orbi ONLY to a point. Can I use another app, maybe Nightwawk, to make changes? I don't use my Android for many apps as it can stop working when overloaded, I don't like using Orbi app on it anyway, not sure how secure it is. Using the router page is never secure even if I enable https, I always get a warning.
Also, on Wifi Analytics, my SSID says Security enabled(Unknown algorithm). I enabled WPA2-PSK so I thought, but on my Preferred networks it says WPA3SAE enabled, so I'm confused. I wasn't sure how secure WPA6 (I think?) is with an old Android.
Any suggestions?
RosieA
Jun 23, 2022Aspirant
A few of my devices say they only work with 2.5MHz, but the SSID defaults to 5MHz, I can't seem to control it. The Orbi default was WPA3, I did change it to WPA2-PSK (my mistake on WPA6)...
