RosieA
Jun 21, 2022Aspirant
Orbi RBR750 / AX4200 - Need Desktop App to Manage it
I finally got this darn thing to connect to internet. I had an old Netgear router and used the Genie app on desktop, and it works with Orbi ONLY to a point. Can I use another app, maybe Nightwawk, ...
RosieA
Jun 24, 2022Aspirant
There is no such choice of "Web Services Management"
This is what it says when I log in via internet:
Visiting an untrustworthy website has been prevented
certificate verification problem detected
Reason: Self-signed certificate View certificate
I understand the risks and wish to continue
Message from my antivirus: Detected connection to an insecure websource: continue?
I did press "continue," however, I am not confident I am doing this safely. Please advise...
CrimpOn
Jun 24, 2022Guru - Experienced User
On my ancient RBR50, Web Services Management appears on the Advanced Tab, Advanced Settings menu:
This is where there used to be an option to allow internet access to the https web administration. Netgear removed that option, and now there is only the choice to require use of https:
I do not have a 750 system to see if the Advanced menu is the same on it.
If you connect to the Orbi over VPN, then all data passing through the connection between your remote laptop and the Orbi is encrypted two times:
- Once by the Orbi using https.
- Then again by the VPN, which encrypts everything.
The web browser knows none of this. When it sees an http connection, it cries UNSAFE. When it sees a self-signed certificate, it cries UNSAFE.
- CrimpOnJun 24, 2022Guru - Experienced User
p.s. I did connect to my Orbi using OpenVPN (through a Hot Spot on my cell phone). https://orbilogin.net did show up and display that UNSAFE message. Opened Attached Devices and there's my laptop connected by "vpn".
