LordChaos
Jun 19, 2023Aspirant
Orbi RBR750 & Qualcomm Atheros QCNFA765
Hi, I received a new laptop two weeks ago, a Lenovo Thinkpad Z13 equipped with a Qualcomm wifi card. I've had zero issues with my Orbi mesh network so far and I'm quite happy with it to be honest. H...
Jun 21, 2023Guru - Experienced User
Are you using wpa3?
have you tried setting it to wpa2 and seeing if it helps?
LordChaos
Jun 21, 2023Aspirant
I'm running WPA2 (AES) at the moment. I tried WPA3 for a brief moment, but the symptoms on this particular laptop are the same with WPA3.
- plemansJun 23, 2023Guru - Experienced User
are you dual booting the device with multiple distros?
happen to have a windows boot drive you could test if its a card issue or a distro issue?
