Wznme
Mar 09, 2025Tutor
ORBI RBR750 / RBS350 satellites - very slow
Hello, In the last month or so, the above setup has become almost unusable for any type of streaming and or use. Have a main RBR750 directly connected to ISP modem/ router ( in bridge mode), with tw...
- Mar 09, 2025
Ok. Understand.
You should be good to go then. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Wznme
Mar 09, 2025Tutor
Yes, I wasn't using the 5Ghz, oinly for backhaul to the rbr750.
I meant, I was using ethernet wired access for my major clients to the rbs350, and eliminated using the 2.4ghz access from the equation.
But anyhow, reducing the one rbs350 seemed to help.
Mar 09, 2025Guru - Experienced User
Ok. Understand.
Enjoy. 📡
