mark0824
Jul 19, 2022Aspirant
Orbi RBR750 / RBS750 All Devices Show Connected to RBR750
Hi all, After getting the update a few weeks back to finally enable me to login using the web and orbi app, a new problem springs up. I have the RBR750 on my main floor (house setup--basement...
Jul 19, 2022Guru - Experienced User
Yes.
I recommend that you update the RBS FIRST to v.5:
Then the RBR lastly.
Use a wired PC connected to the RBR and open up the RBS IP address in a web browser and send the FW file directly to each RBS.
mark0824
Thank you. I updated both RBS's and now some devices are connected to them. I will update the RBK later tonight, although I am now hesitant after updating the RBS's and it all appears to be working better.
Thanks
