tortiseshell
May 06, 2022Aspirant
Orbi RBR750 2.4 ghz extender needed-help me
looking to improve my simplisafe safe outdoor camera connections to the orbi router… what do you recommend? so confusing when researching… thxs! the orbi system is from costco and i have 4 outdoor sim...
CrimpOn
May 06, 2022Guru - Experienced User
More detail would be helpful. Orbi 750 systems provide 2.4G WiFi signals
What part of the installation process is failing?
https://support.simplisafe.com/hc/en-us/articles/360029594812-Installation-Help-for-SimpliCam
- tortiseshellMay 06, 2022Aspiranthey thxs… i wouldnt call it a fail but connection to more distant cams struggle to pull up consistently, esp if other devices are consuming bandwidth. i have a two story house. router is upstairs in an office. 2 sats are on the first floor. simplisafe outdoor cams want 6mb each for upload. i have 40+ of upload bandwidth… simplisafe solution is to put an extender in to help the connection at 2.4 ghz… i just want to get a low cost no bufoonery netgear solution that is compatible with my orbi mesh. so looking for advice which product others think will accomplish my need… open to ideas… thxs!
- tortiseshellMay 07, 2022Aspirantshould also add… simplisafe indoor cams want 2mb for 1080 rez… no mention of their outdoor cams requirements until i talked with them… ugh… so i currently have 4 outdoor cams and 1 indoor cam set to 480 to ease the upload… i sure would like to get to 1080… i know my wifi and isp speeds are good… so hoping an extender will improve my situation.
- plemansMay 07, 2022Guru - Experienced User
what is the exterior of your home made from?
I've seen several times where people have brick exteriors and are trying to connect camera's through brick.
