tortiseshell
May 06, 2022Aspirant
Orbi RBR750 2.4 ghz extender needed-help me
looking to improve my simplisafe safe outdoor camera connections to the orbi router… what do you recommend? so confusing when researching… thxs! the orbi system is from costco and i have 4 outdoor sim...
CrimpOn
May 06, 2022Guru - Experienced User
More detail would be helpful. Orbi 750 systems provide 2.4G WiFi signals
What part of the installation process is failing?
https://support.simplisafe.com/hc/en-us/articles/360029594812-Installation-Help-for-SimpliCam
tortiseshell
hey thxs… i wouldnt call it a fail but connection to more distant cams struggle to pull up consistently, esp if other devices are consuming bandwidth. i have a two story house. router is upstairs in an office. 2 sats are on the first floor. simplisafe outdoor cams want 6mb each for upload. i have 40+ of upload bandwidth… simplisafe solution is to put an extender in to help the connection at 2.4 ghz… i just want to get a low cost no bufoonery netgear solution that is compatible with my orbi mesh. so looking for advice which product others think will accomplish my need… open to ideas… thxs!
