mdjaskolka
Jul 02, 2022Aspirant
Orbi RBR750 (+2 satellites) and Fidium Internet
We recently switched internet services (from XFinity to Fidium). XFinity is DHCP and Fidium is PPPoE. All worked great except for my wife's work laptop and it's VPN. Orbi was connected directly to...
Jul 12, 2022Guru - Experienced User
You'll need to contact your ISP and ask them if there are any requirements they may have in regards to what may or may not be needed to connect the RBR directly to there ONT.
rdonovan111 wrote:
Have you had any success with the Fidium Modem and your Orbi .. I just got Fidium today and should have researched to see if it was compatible with my Orbi (RBR850) i have two of the mesh ones. Worked fine with comcast Gig modem but now just the purple light of death. I haven't called them yet to as for help.
spewak
Jul 14, 2022Luminary
"You'll need to contact your ISP and ask them if there are any requirements they may have in regards to what may or may not be needed to connect the RBR directly to there ONT. "
This is precisely how I run mine. ONT directly to my RBR850, works solidly. You can lose the Fidium equipment and save some money monthly.
- mdjaskolkaJul 14, 2022Aspirant
Had this setup.
Caused VPN issues.
- FURRYe38Jul 14, 2022Guru - Experienced User
Have you tried removing the ISP router and connecting the RBR to the ONT?
Or try the ISP router online with the Orbi system in AP mode?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- mdjaskolkaJul 14, 2022AspirantYes to Ont and Orbi. It's what caused VPN issues and forced me to bring in ISP equipment.
Have tried adding Orbi to ISP router but cannot sign in to it to put it in AO mode.
