ramanmanish
May 24, 2021Follower
Orbi RBR750 access logs missing
Model: Orbi RBR750 Firmware Version: V3.2.18.1_1.4.14 Bought it few months ago from Costco and overall this has given a good performance so far. However, I started to get into rabbithole as soon...
CrimpOn
May 25, 2021Guru - Experienced User
ramanmanish wrote:Model: Orbi RBR750
I have scoured multiple threads, websites but cant get any straight answer. This particular version seems to be incompatible with other products/apps like circle. I am fairly technical but it seems I have exhausted all my option and hence starting this new thread.
If this is a solved issue, please point me to the right location. Or at least, the confirmation that I may have to return this and get some other routers (suggestion welcome)
This Netgear product does not feature any sort of Parental Controls. Check the list of systems supported toward the bottom of this web site: https://www.netgear.com/home/services/smart-parental-controls/ (Notice there are no Orbi AX products, no Nighthawk products.)
In addition, trying to "roll your own" using site blocking fails because that feature applies only to non-secure (http) web sites, which are fast disappearing.
Other brands include this sort of feature in their advertising promotional material. For how they work (and how well they work), only people who own those products can say.
I found this article interesting in that it points out "pros and cons" of several offerings, which provides a framework for investigation. Don't know if I (personally) would agree with their recommendations. It's the factors to consider that I find useful.
https://www.lifewire.com/best-parental-control-routers-4160776
michaelkenward
CrimpOn wrote:Other brands include this sort of feature in their advertising promotional material. For how they work (and how well they work), only people who own those products can say.
For how long they last is another important question:
Netgear has just announced that it is killing the free Live Parental Controls.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
