Lgude01
Nov 01, 2024Follower
Orbi RBR750 After power outage, only the guest wifi and direct connections work.
After power outage only the guest wifi and direct connections to the router are working. The main wifi and satellite connection are not working.
Tried rebooting and resetting without success.
1 Reply
Has this happened before? On Prior FW versions?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What channel configurations are currently set on the router?
