JohnQ5586
May 04, 2024Aspirant
Orbi RBR750 Amazon Prime VPN issue
I've been using the RBR750 mesh and Amazon Prime for a few years with no problem. About 3 weeks ago, all of a sudden Amazon Prime started blocking me from watching any video with the message that it...
- May 23, 2024
could be on Amazon's backend something changed.
If its working, I'd mark it solved so others aren't still trying to fix it.
CrimpOn
May 04, 2024Guru - Experienced User
What a puzzle! Apart from, "this is impossible", I have no idea what's wrong.
Could you please confirm something with an experiment? Both when connected to the Orbi system and directly to the ISP device, check the results of these two web sites:
Do they both show the same information for both Orbi and ISP device?
(including the IPv6 address and the Physical location?)
What device is being used to watch Amazon Prime videos? (besides the laptop?)
JohnQ5586
May 09, 2024Aspirant
When I connected using Wifi or plugged directly into the Orbi hub, I get the same IPv4 address however it is different (last octet) than then IPv4 address when plugged directly into the modem.
The IPv6 address was showing "Not Detected" for all connections.
I usually watch Prime on my Android phone (same "VPN" message as on the laptop).
The phone shows the same IPv4 as the laptop (when it was connected using Wifi or wired to Orbi) and similarly IPv6 showing Not Detected.
The modem is Sercom DM 1000, provided by the ISP.
Thanks
- plemansMay 10, 2024Guru - Experienced User
Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
CloudFlare
IPv4: 1.1.1.1 and 1.0.0.1
IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
GoogleDNS
IPv4: 8.8.8.8 and 8.8.4.4
IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844- JohnQ5586May 22, 2024Aspirant
All of a sudden, the VPN message is gone, I can now watch Prime on my phone or tablet or laptop with exactly the same IP address as before. Nothing as changed on my end but somehow Prime doesn't see it as VPN anymore. Strange?
- plemansMay 23, 2024Guru - Experienced User
