bc87swa
Aug 02, 2021Aspirant
Orbi rbr750 and Nintendo switch problems
edited to add...my model isn't selectable above. We have the RBR750 2021-08-01 05:42 PM Hello, my kids both have the Nintendo Switch and we are unable to ...
Aug 02, 2021Guru - Experienced User
Where are you disabling the 5Ghz broadcast at? I believe that disabling of SSID broadcast is not supported on Orbi AX system.
You can disable AX mode on both radios.
Try setting CTS values from 64 go 2347?
- bc87swaAug 02, 2021Aspirant
Firmware Version
V4.6.3.7_2.0.49We are using the Charter Arris TM1602 with the Orbi RBR750
We just disabled the 5hz on the routerlogin.net for the device.There is a box under the wireless tab to enable each bandwidth broadcast. We just turned of the 5 and tried to connect. Still didn't work....and I'm not sure what the CTS is? I know just enough to be dangerous. Haha.
- FURRYe38Aug 02, 2021Guru - Experienced User
Would you please post a screen capture of this places where your disabling the 5Ghz broadcast so we are sure what your disabling.
Please use the Choose File button on your next post to attached the screen capture file.
CTS is under Advanced Tab/Advanced Settings/Wireless Settings
- Mikey94025Aug 02, 2021Hero
Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to hte Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
