mattg1960
Sep 09, 2022Star
Orbi RBR750 and RBS750 Acting Up Again : (
At the end of May, ChristineT made available firmware V4.6.8.2_2.10T3. My router was restarting multiple times per day and I couldn't see my network on the iPhone app even though when it wasn't resta...
mattg1960
Sep 09, 2022Star
That is the obvious thing to do. But this router is mission critical as we live in a valley with no phone service, so we use Wifi calling exclusively.
The point is to not play firmware lottery.
I'm looking for an explanation why the firmware from ChristineT stopped working.
I just want a high-quality, DEPENDABLE router that won't spy on me. I thought I had found it with the Orbi and paid a premium for it.
I will do a restart this weekend, but for now my wife's calls a Zoom meetings cannot be interrupted.
Any more ideas?
Sep 09, 2022Guru - Experienced User
Is SIP ALG enabled or disabled on your RBR?
I have SIP enabled on mine. I'll check again.
Well I was a a 2 hour long zoom meeting the other day with my mac book pro via wifi. Zero issues.
- mattg1960Sep 09, 2022Star
I can't find a SIP/ALG setting anywhere. When I do a search I get instructions for where it should be but I don't see it (yet).
As for Zoom, it works great when the router isn't restarting and we lose the Wifi signal.
My problem is getting the router back to where it was...NOT restarting multiple times a day.
4.6.8.2 had seemingly solved that problem.
What happened to make it unstable again?
I haven't touched a thing in months...
Just found it : )
The box next to 'Disable SIP ALG in not checked.
'Secured' is checked to the right.
- FURRYe38Sep 10, 2022Guru - Experienced User
Let us know if that changes anything. IF so, you should update FW.
