stephen777's avatar
Nov 16, 2021
Orbi RBR750 and RBS750 not syncing in AP mode
Hi,   I recently decided to buy a pfsense firewall and set it up and switched my Orbi to AP mode. The router works fine, but the Satellite won't sync and keeps showing a solid magenta light. I tr...
  • stephen777's avatar
    stephen777
    Nov 20, 2021
    So, I adjusted my set up a little bit.  I disconnected my pfsense firewall altogether and factory reset my RBR750 again.  I set up my RBR and RBS together in Router mode as normal, but I moved the RBR from being plugged directly into the switch to being plugged directly into the pfsense firewall.  So now my setup looks like this: Modem > Firewall > RBR750 > Switch rather than Modem > Firewall > Switch > RBR750.  I also ensured that RBR was connected to the firewall via the WAN port and now the RBR and RBS are talking.
    So it seems that the RBR needs to remain in front of the switch rather than behind it.  At least in my instance.
    I appreciate your help on this and the troubleshooting you assisted me with!
