stephen777
Nov 16, 2021Tutor
Orbi RBR750 and RBS750 not syncing in AP mode
Hi, I recently decided to buy a pfsense firewall and set it up and switched my Orbi to AP mode. The router works fine, but the Satellite won't sync and keeps showing a solid magenta light. I tr...
- Nov 20, 2021
So, I adjusted my set up a little bit. I disconnected my pfsense firewall altogether and factory reset my RBR750 again. I set up my RBR and RBS together in Router mode as normal, but I moved the RBR from being plugged directly into the switch to being plugged directly into the pfsense firewall. So now my setup looks like this: Modem > Firewall > RBR750 > Switch rather than Modem > Firewall > Switch > RBR750. I also ensured that RBR was connected to the firewall via the WAN port and now the RBR and RBS are talking.
So it seems that the RBR needs to remain in front of the switch rather than behind it. At least in my instance.
I appreciate your help on this and the troubleshooting you assisted me with!
CrimpOn
Nov 17, 2021Guru - Experienced User
stephen777 wrote:
I recently decided to buy a pfsense firewall and set it up and switched my Orbi to AP mode. The router works fine, but the Satellite won't sync and keeps showing a solid magenta light. I tried hardwiring the Satellite into my switch and I got a solid blue light. So, something is happening that isn't allowing the two to pair, but I'm not sure what it would be.
Was the Orbi system paired before switching to AP mode?
stephen777
Nov 18, 2021Tutor
I've tried it both ways. Originally, yes, it was paired before switching. Then I factory reset them and tried not connecting them first.
- CrimpOnNov 18, 2021Guru - Experienced User
Factory reset returns the Orbi to router mode. An Orbi system that is paired in router mode should remain paired when it is swithed to AP mode.
- stephen777Nov 19, 2021TutorYes, I understand that it returns it to router mode. As mentioned, after the factory reset, I paired them after switching to AP mode since the first time they were already paired before switching to AP mode.
As mentioned, neither has worked.- FURRYe38Nov 19, 2021Guru - Experienced User
Are you using a Dynamic or Static IP address on the RBR when in AP mode?
