bosa84
Sep 15, 2021Guide
Orbi RBR750 and Satellite suddenly started dropping WiFi Devices
I have an Orbi RBR750 plus one satellite (connected via Lan). Everything worked great for many months, but a few weeks ago the Orbis started disconnecting iPhones and iPads. Sometimes once a day...
Sep 15, 2021Guru - Experienced User
Is the RBS connected directly the the back of the RBR or is there any LAN swtich in between?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- bosa84Sep 15, 2021Guide
Thanks FURRYe38, answers below:
-> the latest: V4.6.3.16_2.0.51
-> Arris TM1602 (but that did not change)
-> There is Netgear GS105 in between, but that also did not change and was working fine for months
-> Using Auto. I will try your recommendationsAny Wifi Neighbors near by? If so, how many?
-> About 5
Armor.
-> was always disabled
-> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations- FURRYe38Sep 15, 2021Guru - Experienced User
-> About 5
Armor.
-> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations< Remove the check mark from the box then select apply. This sets 40Mhz only.
Has a power off for 1 minute then back ON with the ISP modem, Switch and Orbi system been performed since last update? - raven_auSep 15, 2021Virtuoso
bosa84 wrote:Thanks FURRYe38, answers below:
I presume that you have checked if forgetting the wireless connection on your mobile device and re-connecting it helps.
The new firmware update you are using may have included an update to the wireless drivers and the device parameters could need refreshing.
- bosa84Sep 16, 2021Guide
I will methodically go through the suggested changes.
Yesterday I did this: Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
It seemed to work better this morning, but by mit day it started dropping iOS devices again.
I use 2 iPads. Once one gets dropped, I sometimes can simply reconnect, but often the first bit of network activity then makes it drop again. Then I did let it sit for 5 minutes and the reconnect and then wait another 5 minutes until I start using it for network stuff. That worked better, but next thing my iPhone get kicked out of the WiFi.
It really feels like the Orbis are just overwhelmed with juggling the iOS devices.
Will try the 'forget network' on all iOS next. After that I'll try the channel settings you recommended.
Thanks again!
- FURRYe38Sep 16, 2021Guru - Experienced User
Try setting 2307 for CTS.
Try disabling AX mode as well...
Others have mentioned doing a reset and setup from scratch is helping them...
Thanks again!
