bosa84
Sep 15, 2021Guide
Orbi RBR750 and Satellite suddenly started dropping WiFi Devices
I have an Orbi RBR750 plus one satellite (connected via Lan). Everything worked great for many months, but a few weeks ago the Orbis started disconnecting iPhones and iPads. Sometimes once a day...
bosa84
Sep 15, 2021Guide
Thanks FURRYe38, answers below:
-> the latest: V4.6.3.16_2.0.51
-> Arris TM1602 (but that did not change)
Is the RBS connected directly the the back of the RBR or is there any LAN swtich in between?
-> There is Netgear GS105 in between, but that also did not change and was working fine for months
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
-> Using Auto. I will try your recommendations
-> About 5
Armor.
-> was always disabled
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
-> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations
Sep 15, 2021Guru - Experienced User
What is the size of your home? Sq Ft? What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
-> About 5
Try disabling the following and see: Armor.
-> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations< Remove the check mark from the box then select apply. This sets 40Mhz only.
Has a power off for 1 minute then back ON with the ISP modem, Switch and Orbi system been performed since last update?
