bgibs2003
Jun 12, 2021Tutor
Orbi RBR750 and Wired Satellites
Hi - I have the RBR750 with two satellite setup. For each satellite, I have a wired ethernet connection. However, when I plug in the ethernet (to get the full speeds), they stop working uniformly. ...
michaelkenward
Jun 13, 2021Guru - Experienced User
bgibs2003 wrote:
I also noticed that a separate domain (Router is on 172.16.0.x) and one of the two satelites is on 192.168.1.x.
That first IP address smells like some sort of local configuration issue.
It suggests that something has detected "a conflict with a WAN IP address".
What do you see when you aim a browser at the 172.16.0.x address?
You are in the wrong place for that. You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here. However the Orbi system uses some very different technologies from standard routers, especially with satellites, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
