orbiuser1975
Dec 30, 2020Apprentice
Orbi RBR750 Backhaul Connections Reported Incorrectly
Just installed a RBR750 router/satellite system. Both the router and satellite have firmware V3.2.16.22_1.4.9. The satellite backhaul connection is via CAT5e through a switch (not direct). Couple of...
Dec 30, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
No.
No.
orbiuser1975
Orbi is operating as a router.
It is a simple unmanaged 1Gbps switch, TRENDnet TEG-S16Dg.
https://www.trendnet.com/products/product-detail?prod=235_TEG-S16Dg
- FURRYe38Dec 30, 2020Guru - Experienced User
Does the RBS appear correctly in the RBRs web page as a wired RBS?
