orbiuser1975
Dec 30, 2020Apprentice
Orbi RBR750 Backhaul Connections Reported Incorrectly
Just installed a RBR750 router/satellite system. Both the router and satellite have firmware V3.2.16.22_1.4.9. The satellite backhaul connection is via CAT5e through a switch (not direct). Couple of...
orbiuser1975
Orbi is operating as a router.
It is a simple unmanaged 1Gbps switch, TRENDnet TEG-S16Dg.
https://www.trendnet.com/products/product-detail?prod=235_TEG-S16Dg
Dec 30, 2020Guru - Experienced User
Does the RBS appear correctly in the RBRs web page as a wired RBS?
