FaronSKN
Jun 30, 2023Aspirant
ORBI RBR750 Backhaul Status always Out of Sync with it's 4 Satellites
Good Day. I've been trying to figure out why my set of ORBI's (Router and 4 Satellites) have never shown a 'Good' Backhaul Status with each other. It's always shown Out of Sync, even though the Satel...
FaronSKN
Firmware Version is V4.6.14.3_2.3.12
The Cat6 connection to the ORBI Router is tested and fine. There are no nearby neighbors and the ORBI's are between 25ft to 40ft from the Router.
Backhaul Connection type is 5GHz
Wireless Setting: 5GHz on channel 44. ORBI Router is in AP Mode
Keep in mind that these ORBI Satellites showed Out of Sync even when they were right next to the Router
Jun 30, 2023Guru - Experienced User
Are you able to log in to the RBS and ensure the FW is the same version on the RBS?
Turn off all but one RBS and test with just one RBS while near the RBR.
Is the RBR in AP mode configured for Dynamic or Static IP address configuration?
What is the Mfr and model# of the host router the RBR router is connected too?
