james0169
Apr 26, 2024Aspirant
ORBI RBR750 blocking devices from the internet, again
Our Orbi RBR750 blocked a couple of devices about 8 weeks ago. I thought it was an ISP problem and called them. They were really helpful and went through a few checks, then identified that the Orbi h...
Apr 26, 2024Guru - Experienced User
You can disable access control
james0169
Thanks for the feedback and suggestion.
When we turned off access control a couple of weeks ago and applied the change. When I went back in yesterday it was turned on! Don't know why.
We disabled access control and saved the change. Devices were still blocked.
Went back in and allowed the devices and then turned off access control, however when saving the change it blocked everything again!!
Last night I allowed all devices, left access control on and saved the change. This moring, everything is blocked again....
When you pay good money for an Orbi system thinking you are buying some quality, this is very frustrating. Has worked for a couple of years with no problem and then bang!! I don't think you should have to do hard factory resets once it is set up.
Ready to smash it with a hammer.
- plemansApr 27, 2024Guru - Experienced User
I don't think you should have to do factory resets either but sometimes firmware changes enough or something gets corrupted so it can fix things. Its always worth a short with a misbehaving system.
