amsimmons
Dec 17, 2020Follower
Orbi RBR750 bug with firmware V3.2.16.22
I'm not sure how to get this to the right people (Netgear doesn't make it easy to contact them), but there is a major issue with the firmware version that was recently released and automatically down...
Dec 17, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? If not, power OFF the ISP modem for 30 seconds then back on while you reset the RBR. Then walk thru the setup wizard with a wired PC and web browser at 192.168.1.1 or orbilogin.com
