amsimmons
Dec 17, 2020Follower
Orbi RBR750 bug with firmware V3.2.16.22
I'm not sure how to get this to the right people (Netgear doesn't make it easy to contact them), but there is a major issue with the firmware version that was recently released and automatically down...
Mstrbig
Dec 17, 2020Master
I have been running firmware V3.2.16.22 since it was pushed to my RBK753 system. I also have it updated on several other RBK753 systems. I can say with confidence, your issue is not due to a bug with the firmware, as all my systems have been running flawlessly, with over 20 connected devices.
After you updated your satellites and router to firmware V3.2.16.22, did you reboot your system? Did you check your settings to verify the update didn't change any of them?
Also you may want to try a couple of IP reservation settings for your satellites, so they don't change if there is a reboot or power failure.
intergeek14
Jan 02, 2021Star
I also had issues with connectivity and slower speeds when updating. Rolling back to V3.2.16.6_1.4.4 fixed my issues.
- FURRYe38Jan 02, 2021Guru - Experienced User
