amsimmons
Dec 17, 2020Follower
Orbi RBR750 bug with firmware V3.2.16.22
I'm not sure how to get this to the right people (Netgear doesn't make it easy to contact them), but there is a major issue with the firmware version that was recently released and automatically down...
Rhmorgan67
Jan 13, 2021Guide
There is ABSOLUTELY an issue with this firmware update. I'm rolling back too. Every two hours like clockwork my router times out. My ISP says they aren't getting a reply back from the router for lease renewal.
Jan 13, 2021Guru - Experienced User
Did you perform a factory reset and setup from scratch when you had v22 loaded?
- Rhmorgan67Jan 13, 2021Guide
I have now done that. Current lease expires in 28 minutes... I'll let you know if it stops again or keeps on rolling... I did the full paperclip, start from scratch set-up, so hopefully it will be successful.
It dropped again. I even had the ISP on the other line right when the lease renewed and everything looked perfect on their end...
- FURRYe38Jan 13, 2021Guru - Experienced User
Try downgrading to v6 FW.
Rhmorgan67 wrote:It dropped again. I even had the ISP on the other line right when the lease renewed and everything looked perfect on their end...
