Philly_503
Jan 16, 2021Follower
Orbi RBR750: Cannot See SSID to Connect Laptop
Installed an Orbi RBR750 and changed the SSID/security key to an existing SSID/security key on the existing router AFTER shutting it down for home replacement. All devices picked up the new Orbi. T...
No1Mportnt
Jan 16, 2021Luminary
You should be able to pick your WiFi network from the ones available then all you should have to do is enter you password for the network.
