Philly_503
Jan 16, 2021Follower
Orbi RBR750: Cannot See SSID to Connect Laptop
Installed an Orbi RBR750 and changed the SSID/security key to an existing SSID/security key on the existing router AFTER shutting it down for home replacement. All devices picked up the new Orbi. T...
Jan 20, 2021Guru - Experienced User
Any progress on this?
Philly_503 wrote:Installed an Orbi RBR750 and changed the SSID/security key to an existing SSID/security key on the existing router AFTER shutting it down for home replacement. All devices picked up the new Orbi. Tried to connect a few days later with a work laptop by adding a new network in Wifi/Manage known networks. Filled out Network name, Security type WPA2-Personal AES, Security Key information, and connect automatically. Received reply " Couldn't add the new nework". Is this an issue with security settings on the PC not allowing access to add a new network or is there a conflict with reusing the same SSID/security key and this PC was.not available when this change occurred?
Thank you
