Philly_503
Jan 16, 2021Follower
Orbi RBR750: Cannot See SSID to Connect Laptop
Installed an Orbi RBR750 and changed the SSID/security key to an existing SSID/security key on the existing router AFTER shutting it down for home replacement. All devices picked up the new Orbi. T...
Mikey94025
Jan 20, 2021Hero
Might be an Orbi AX compatibility issue with older wireless devices. Try going to orbilogin.com, Advanced tab, Advanced...Wireless Settings and change CTS/RTS Threshold to 2347 for both bands and see if it helps. You can also try disabling AX mode in Setup...Wireless Setup.
