Sir_Argo
May 16, 2022Aspirant
Orbi RBR750 can't connect to app or admin page / firmware issue
I am aware this issue has already been reported. links include: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Orbi-Web-Page-and-Orbi-app-Access-Status/m-p/2223086 https://sta...
Sir_Argo
May 28, 2022Aspirant
I see that NetGear has a fix. Their message was posted 5/23 and said they were rolling it out over the next 10 days, which would mean through June 2nd. Their message didn't say how I would know if I had received the fix. I guess if I am able to access the admin page, then I got the fix.
But how do I know that I haven't already got the fix, but it isn't working? Is there a notification that the fix was applied?
They said they are rolling it out over the next 10 days. How are they selecting who gets it on day 1 vs. who gets it on day 10? If they are going by serial number, or ip address, or some other identifiable criteria, then I should be able to check the schedule and see what day I am to receive it.
What happens if my router is powered off when my turn to receive the patch comes up? Do I just miss out?
Is there a way to download and apply the patch myself?
Thank you in advance,
Darren
May 28, 2022Guru - Experienced User
But how do I know that I haven't already got the fix, but it isn't working? You'll need to contact NG support. Is there a notification that the fix was applied? No.
They said they are rolling it out over the next 10 days. How are they selecting who gets it on day 1 vs. who gets it on day 10? They don't tell us that information. If they are going by serial number, or ip address, or some other identifiable criteria, then I should be able to check the schedule and see what day I am to receive it. Users have been contacting NG support and giving there product serial numbers and getting there systems corrected from what I can tell.
Just make sure it's always online.
Is there a way to download and apply the patch myself? No.
You can do factory reset on the RBR if you need more immediate access. Otherwise you'll need to wait for NG to push something or make contact with NG support and ask to get this patch.
https://my.netgear.com/support/contact.aspx
