jtadd
Oct 01, 2020Tutor
Orbi RBR750 Clear VLAN Settings on Reset
My Orbi RBK753S-100NAS Orbi AX4200 Tri-Band Mesh Wi-Fi System AX Wifi 6 Router is Clearin VLAN Settings on reset or power cycle. I have Fiber internet and I bypass my ISP "Gateway" and bring the...
Oct 01, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? Then configure VLAN settings?
IF this has been done already and the configuration still disappears or gets cleared after a power cycle, you'll need to contact NG support and file a support ticket and have them help you with this.
In the interrim, after you configure the RBR and VLAN settings, do a back up to file so you can go in and re-load the configuration with VLAN settings and get the RBR back up and running quicker.
