WiscWildcat
Sep 26, 2023Aspirant
Orbi RBR750 Constantly Drops Azure VPN Signal
I need the Azure VPN for work, but it drops constantly. Sometimes it will only be up for 30 seconds, usually it drops every 6 minutes, occasionally it will stay up for a few hours.
I missed the...
- Sep 29, 2023
I'm going to rule this IP change a successful fix -- I'm still connected, two days later, including over two nights. Gotta break that string, though. Windows wants updates. â
So, to anyone else with this issue -- first just try a simple Router reboot just in case that's all that's needed.
If that doesn't fix it, go into your Netgear Admin, Advanced, LAN Setup, and change the starting IP address of your DHCP server to something higher.I set mine to 150, but I am going to experiment when no one else is home to see if a lower range will still work, and to take it off altogether to make sure this was, indeed the problem, and not something a simple router reboot would have fixed.
Sep 26, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If other VPN client SW is working with the Orbi system and Azure isn't, something to contact them about and see if they can give you some help and pointers. May not be a Orbi issue. Check with Azure tech support.
The RBR LAN IP address is 192.168.1.1 and all other connected clients will get an IP address in the range of 192.168.1.2 to .254. VPN is just a private IP addres network that runs thru the 192.168 domain is all.
Might review information regard new FW at somepoint after narrowing down the problem with the one VPN.
WiscWildcat
Sep 27, 2023Aspirant
Thank you for your reply.
Internet Service is Spectrum. No problem at all for years with Cisco or Barracuda VPN's, so I have already been leaning on Azure.
I just changed my DHCP to only server 192.168.1.150 thru 254 since the Azure VPN -- which ultimately serves up a 10.193.xxx.xxx range -- seems to favor the lower levels where Orbi likes to live, and rebooted the router.
Been connected for about a half hour now with no kickout. Fingers crossed. Since I sometimes can stay connected for a couple hours, I'm guessing it's an IP conflict and others on this forum have solved the problem this way (although none of them - dammit - ever mention what range they switch their DHCP to, which can be infuriating when you're trying to emulate their success).
I have no idea what you mean by "Might review information regard new FW at somepoint...".
- FURRYe38Sep 27, 2023Guru - Experienced User
There is new firmware for the 750 series.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ- WiscWildcatSep 27, 2023Aspirant
Thanks, but I will respectfully decline to mark it as solved until I've gone a few days without a constant disconnect.
Let us know.
