WiscWildcat
Sep 26, 2023Aspirant
Orbi RBR750 Constantly Drops Azure VPN Signal
I need the Azure VPN for work, but it drops constantly. Sometimes it will only be up for 30 seconds, usually it drops every 6 minutes, occasionally it will stay up for a few hours.
I missed the...
- Sep 29, 2023
I'm going to rule this IP change a successful fix -- I'm still connected, two days later, including over two nights. Gotta break that string, though. Windows wants updates. â
So, to anyone else with this issue -- first just try a simple Router reboot just in case that's all that's needed.
If that doesn't fix it, go into your Netgear Admin, Advanced, LAN Setup, and change the starting IP address of your DHCP server to something higher.I set mine to 150, but I am going to experiment when no one else is home to see if a lower range will still work, and to take it off altogether to make sure this was, indeed the problem, and not something a simple router reboot would have fixed.
Sep 27, 2023Guru - Experienced User
There is new firmware for the 750 series.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
WiscWildcat
Sep 27, 2023Aspirant
Thanks, but I will respectfully decline to mark it as solved until I've gone a few days without a constant disconnect.
- FURRYe38Sep 27, 2023Guru - Experienced User
Let us know.
