smoothRyl321
Aug 26, 2021Aspirant
Orbi RBR750 custom LAN IP. Orbi App cannot connect to system
I have an Orbi RBR/RBS750 meshed system. I have a custom LAN subnet of 15.15.15.0/24. Router IP is 15.15.15.1. Ever since I change to a custom subnet, I can no longer log into the Orbi App. Has anyon...
Aug 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Please avoid using any IP addresses outside of the following range for home class routers, 10, 172 and 192.
Thank you.
smoothRyl321 wrote:
I have an Orbi RBR/RBS750 meshed system. I have a custom LAN subnet of 15.15.15.0/24. Router IP is 15.15.15.1. Ever since I change to a custom subnet, I can no longer log into the Orbi App. Has anyone ever experienced this?
You would think that a different IP other than 192.168.1.1 should work.
As you see in the screenshots, the system is showing online with the green bubble and check mark.
