m71
Oct 03, 2021Follower
Orbi RBR750 do not connect satellites after firmware 4.6.3.16 (latest)
Satelltes stopped showing no devices connected and magenta dot in Orbi app (noy on router front) . Niticed router was on latest formware 4.6.3.16 Repeated attemps to sync failed including re...
Oct 19, 2021Guru - Experienced User
Any progress on this?
This is supposed to be fixed here:
Repeated attemps to sync failed including reset
Removed satellites and they stopped showing again or was not abel to add again.
Finally manually updated to older Firware V4.6.3.7_2.0.49 and satellites satrted showing up again as well as devices shows connected again to satellites.
Looks like a serious bug in 4.6.3.16
This is any fyi if Net gear support is listening as spend hours trying to sync and was pure waste of time .
Any one having issue with this version please revert to older firware.
