palancu
May 12, 2021Aspirant
Orbi RBR750 does not show connected devices after firmware update
Orbi RBR750 does not show connected devices after firmware update to version 3.2.18.1_1.4.14. The router and two satellites show only a max of four devices connected to the router itself (when th...
May 12, 2021Guru - Experienced User
Do you have the CBR750 or RBR750?
palancu
The device is an RBR750.
- palancuMay 12, 2021Aspirant
After reading my own reply I see that applying the CBR update to the RBR device was never going to work. So, let's put that aside as a dumb mistake. But still, latest RBR750 firmware not showing connected hosts...
- FURRYe38May 12, 2021Guru - Experienced User
For any FW updates for the RBR, please review here:
https://www.netgear.com/support/product/rbk752.aspx
Has a power off for 1 minute then back ON with the Orbi system been performed since last update?
Can you select Choose File button on the next post and attach a screen capture of the RBR connected device page?What browser are you using?
