Nick-Hack
Jun 27, 2024Tutor
Orbi RBR750 doing odd DHCP things
Rather a long question. The essence is: how can I configure my RBR750 to stop meddling with things? Firmware: V7.2.6.31 I have a somewhat complicated network for a home system. Briefly, fibre co...
- Jun 30, 2024
I think it's fixed.
The system has been running without a glitch for several days now. What seemed to do it was:
1) Hard reset of the RBR750 by holding a pin in the hole for 20 seconds
2) Setting it up with a laptop plugged into the Orbi
3) Telling it to skip trying to set up satellites.The satellites are working. The "Router" is working as a wireless access point. Whether they are aware of one another, I neither know nor care. The non-Orbi access points are fine. It is time to stop tinkering and take the win.
Thank you to everyone for your helpful suggestion.
Nick-Hack
Jun 30, 2024Tutor
I think it's fixed.
Jul 01, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
