TheFinalProphet
Apr 28, 2021Guide
Orbi RBR750 drops internet every 24 hours
Every 24 hours, my Orbi RBR750 will drop the internet connection and not work for any devices, even those hardwired in. ALL devices plugged into it or on it's wifi do not get internet access. I can i...
Apr 28, 2021Guru - Experienced User
Something to contact NG support about and let them know what your seeing between the versions of FW that you have tried.
Possible a FW issue and something with handling of your particular ONT as well.
A power cycle of the ONT for 1 minute as well should have been performed when you updated FW.
Contact NG support and let them know what you saw.
https://www.netgear.com/support/#
Good Luck.
- rbk750May 04, 2021Tutor
I have exactly same issue on my RBR750.
I need to stay at version 3.2.16.6 to make it work, any version above will not work (disconnection few times a day).
I was able to prevent upgrade in the past month by setting "auto_upgrade_enable=0" and various other configs.
However, recently since last friday/saturday, my router got upgrade to 3.2.18.x every night, and I wake up with no internet connection everyday. I need to rollback to 3.2.16.6 each day, and I also tuned various other configs to see if auto upgrade can be disabled, no luck so far.
there are various configs being set automatically during startup even after I clear these configs:
such as
control_cloud_backend_return_url=https://http.fw.updates1.netgear.com/rbr750/V3.2.18...
control_cloud_backend_download_ur
some suspicous auto upgrade pipe is opened, such as:
... root ... S abFifo /tmp/auto_fw_upgrade_daily /tmp/data2/auto_fw
... root ... S abFifo /tmp/auto_fw_upgrade_force /tmp/data2/auto_fwI have spent many hours fighting with NG support for this issue one/two month ago without any resolution.
All I need is a way to complete disable auto upgrade until the issue is fully resolved.
I really appreciate someone could help.
- FURRYe38May 05, 2021Guru - Experienced User
Are you powering OFF the RBR and RBS for 30 seconds then back ON after the units update?
Try a factory reset and setup from scratch as well. https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
rbk750 wrote:I have exactly same issue on my RBR750.
such as
- rbk750May 05, 2021Tutor
I tried factory reset multiple times before, e.g., after upgrade to 3.2.16.22, 3.2.17.12, after roll back to 3.2.16.6. none of these work.
The only version that works for me is 3.2.16.6 or before.
I got auto upgrade again last night, and then disconnection few hours after upgrade (unplug/replug the ethernet cable, or check the connection status on the web gui page will connect router back to internet).
Plan to rollback 3.2.16.6 again, Please advice a way to prevent auto upgrade.
- sriorbiJul 09, 2021Aspirant
I downgraded the firmware and it worked for me. I had the same issue which was very frustrating experience to say the least. Thank you for your information. very helpful.
I can't seem to see Netgear acknowlegde this issue with a mention of resolution date. I expected a better quality, support and response from Netgear.
- FURRYe38Jul 09, 2021Guru - Experienced User
What FW version did you downgrade too?
Make contact with NG support to advise them on your experiences and let them know.
sriorbi wrote:I downgraded the firmware and it worked for me. I had the same issue which was very frustrating experience to say the least. Thank you for your information. very helpful.
