wjberey
Sep 12, 2021Aspirant
Orbi RBR750 firmware login issues
Can't login as admin to Orbi RBR 750 router. If I reboot it I can log in immediately after the reboot but within a short amount of time I cannot get in again (it clocks infinitely). I'm assuming I ...
wjberey
Thanks for replying. The browser (whichever I use) just clocks indefinitely. Doesn't even bring up the login. If i reboot the router the browser brings me right to the login and i can get in no problem but this only lasts for a short while before i go back to login again and the browser clocks indefinitely again.
CrimpOn
Sep 12, 2021Guru - Experienced User
This took me a while to understand. Clock means that a circular symbol appears and looks similar to a clock face spinning? And, this is before the authentication box appears? (see attached image) When I enter "admin" and the admin password, there is a brief period of "clocking" before the Orbi home page appears. But, only a few seconds.
As this appears with more than one browser, have you tried a different device? (doesn't have to be a computer. Even a smartphone browser can bring up the Orbi web page. (It won't be useable, what with the phone screen being so small, but it should appear.)
- wjbereySep 13, 2021AspirantYes. Does not work on any device. Maybe I should have said page loads indefinitely without ever bringing up login. Very strange because if i unplug Orbi and then plug it back it to reboot I can get to the login right away from any device or browser.
