wjberey
Sep 12, 2021Aspirant
Orbi RBR750 firmware login issues
Can't login as admin to Orbi RBR 750 router. If I reboot it I can log in immediately after the reboot but within a short amount of time I cannot get in again (it clocks infinitely). I'm assuming I ...
Sep 13, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
wjberey wrote:
Can't login as admin to Orbi RBR 750 router. If I reboot it I can log in immediately after the reboot but within a short amount of time I cannot get in again (it clocks infinitely). I'm assuming I need to change a firmware setting to allow me to access the firmware without having to reboot each time. Appreciate any help. Thanks in advance.
