GHTech
Sep 17, 2023Initiate
Orbi RBR750 Firmware V4.6.14.3 -> 7.2.6.21 ???
Hi, I have Orbi 1 RBR750 and 2 RBS750 on firmware version V4.6.14.3. When I try the auto update option on the app and web UI, it looks like it is up to date. When I search the NETGEAR site, it sh...
michaelkenward
Sep 17, 2023Guru - Experienced User
GHTech wrote:
I have Orbi 1 RBR750 and 2 RBS750 on firmware version V4.6.14.3. When I try the auto update option on the app and web UI, it looks like it is up to date. When I search the NETGEAR site, it shows 7.2.6.21 as available.
Did you read this?
RBR750 / RBS750 Firmware Version 7.2.6.21 - NETGEAR Support
Or:
How do I manually upgrade firmware on my Orbi router using orbilogin.com? - NETGEAR Support
GHTech
michaelkenward Thanks. I did read those pages after I posted this question, and went ahead and upgraded the firmware on all 3 devices manually. Seems to be working fine. What threw me off was the fact that the version numbering changed significantly.
- michaelkenwardSep 17, 2023Guru - Experienced User
Me too. That usually signifies a big change. Instead it lists trivial tweaks.
- FURRYe38Sep 17, 2023Guru - Experienced User
This may offer a couple of more details about the update:
