alantomkins
Sep 14, 2023Follower
Orbi RBR750 firmware versions 4.6 and 7.2 which is correct?
There seems to be a large jump from the v4 to the v7 firmware. Is this correct? I have v4 at the moment and the app is showing there are no updates which is odd. Should I install v7?
QUESTION 2:
I am using my Orbi as an ACCESS POINT attached to a Plusnet router. How do update the firmware on this?
Thanks, Alan
1 Reply
- Yes. The current firmware is v7.2.6.21
https://www.netgear.com/support/product/rbr750#download - Download the new firmware for satellite and router.
Extract the firmware images from the zip files.
Follow these instructions:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
