davisfam95
Dec 10, 2020Tutor
Orbi RBR750 Forwarding Ports
I am trying to figure out how to solve the double NAT problem on my gaming consoles and was wondering the best way to port forward for Orbi. I am using the RBS750 Orbi Satellite upstairs away from t...
davisfam95
Dec 11, 2020Tutor
My family uses an Xfinity modem/router
Model:TG3482G
Vendor:ARRIS Group, Inc.
Yes I have been on bridge mode and it has been better but I still get Double NAT I would say 1/4 times I test the NAT type on my xbox one S.
Thank you again for your response!
Dec 12, 2020Guru - Experienced User
Setup a IP address reservation ON the RBR for the xbox when it ON. When you go save and apply the setting, hold the front power button on the xbox until it shuts OFF. Be usre uPnP is enabled on the RBR and no other port foward configurations are enabled. After the RBR has saved the change and rebooted, power ON the xbox. Check NAT status on the networking dashboard.
