Clakhu
Dec 04, 2023Aspirant
Orbi rbr750 geofencing issue
Hi, is anyone experiencing geofencing issues with their Orbi products? 3 of my apps that control heating and security relies on geofencing. When I’m at home those apps notify me that I’ve left the vi...
- Dec 06, 2023
My point exactly. Once the phone running the Arlo app learned where the WiFi system was (for 9nine months), it took some time for it to "re learn" the new location (back home again). Now that the app has adjusted, there is nothing else required.
If you ever feel the urge to "do something goofy", I'd love to hear what happens if you perform that experiment.
CrimpOn
Dec 06, 2023Guru - Experienced User
As I suspected, the Arlo instructions for geofencing specifically mention GPS and say that WiFi is "optional".
https://kb.arlo.com/1085093/How-does-Arlo-Geofencing-work-and-how-do-I-set-it-up
Have downloaded the Orbi configuration file numerous times. The configuration specifically mentions the Time Zone, but contains absolutely nothing about physical location. (No street address. No coordinates. etc.)
When moving to the new location, did you open the Arlo app and change the definition of "Home"?
Clakhu
Dec 06, 2023Aspirant
Nope, we moved out to do renovation work so just boxed my Arlo until we moved back home
- CrimpOnDec 06, 2023Guru - Experienced User
The Orbi router was also boxed up and not powered up at a different location?
- ClakhuDec 06, 2023AspirantI took it with me & used it in at my temporary address for 9 months
