chimerical
Apr 01, 2024Follower
Orbi RBR750: How do I reset the admin login?
Hi team, I have an Orbi RBR750 and used to able to log into the admin dashboard using either the Orbi mobile app or by going to routerlogin.com. The default password doesn't seem to work (admin/password), and I can't seem to find a way to initiate a password reset. What are my options besides a factory reset?
1 Reply
To set up password recovery: https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-feature
Launch an Internet browser from a computer or mobile device that is connected to your router’s network.
Type http://www.routerlogin.net or http://www.routerlogin.com.
A login window opens.
Enter the router user name and password.
The user name is admin. The default password is password. The user name and password are case-sensitive.
The BASIC Home screen displays.
Select ADVANCED > Administration > Set Password.
The Set Password screen displays.
Select the Enable Password Recovery check box.
Select two security questions and provide answers to them.
Click the Apply button.
Your changes are saved.If this fails, then:
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to 192.168.1.1 or orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on. https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
