WGuse
Jan 23, 2025Follower
ORBI RBR750, how to enable the 2.4 GHz for camera and doorbell connection
Need to connect a camera to a 2.4 GHz WiFi .
2.4Ghz is enabled by default on the RBRs main WLAN.
If you have v7 FW loaded on the RBR, then you can setup the separate IoT network for the devices and set 2.4Ghz only there on the RBRs web page.
https://kb.netgear.com/000064267/How-do-I-enable-or-disable-the-Internet-of-things-IoT-network-on-my-Orbi-WiFi-6E-System
https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-System- FURRYe38Guru - Experienced User
One can use the GN however be aware that if your IoT device has a dependent associated app with it on a phone or pad, if the phone or pad is connected to the main WLAN, the app will fail to connect to the IoT device connected on the GN due to the isolation between the main WLAN and GN.
