eglue
Nov 21, 2022Aspirant
Orbi RBR750 IP address is odd to me
Hello cool Netgear community. I noticed something odd that I could use someone to tell me if this is normal or not ideal. My home network issues IP addresses on 192.168.0.x, with 192.168.0.1 bein...
- Nov 21, 2022
eglue wrote:
most of my devices are getting 192.168.0.XXX
I suppose I should have all these devices on the same network, right? Orbi shouldn't be on a different subnet, assuming I want all my devices to play together. How do I go about forcing Orbi to drop the .1?
If the Orbi is placed in Access Point (AP) mode, then the ISP router will assign all IP addresses in the 192.168.0.x IP subnet and everything will be in the same network.
This accomplishes several goals:
- All devices are in the same IP subnet.
- There is no longer a "Double NAT", which can interfere with specific internet applications. (Thousands of users have a Double NAT and are blissfully unaware. Those who are affected learn very quickly that "something is wrong.")
- None of the Orbi router functions remain enabled. No Armor. No Parental Controls. No OpenVPN. etc. etc.
Nov 21, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #1 or 2.
Seems like the printer is carrying over it's configuration possibly when it connects to the Orbi system or is getting past thru from the host router thru the Orbi system.
You may want to set a static IP address ON the printer or set a IP address reservation for the printer on the host router or the Orbi system if you want it connecting to the Orbi system. Contact the printers Mfr support site for help and information regarding there product.
eglue
v4.6.9.11
I have sadly pay too much to Verizon for their router... a G3100
Reading comments. Thank you!
- FURRYe38Nov 21, 2022Guru - Experienced User
- eglueNov 22, 2022Aspirant
Thank you both! That's very helpful.
Ideally, I would make my Orbi's access points across the whole network because the Verizon router seems a pretty decent in controls. I do dislike paying rent on it but I'm so far happy with it.
I'm looking through the Orbi app on my phone, and it doesn't seem to have a way to configure it. I'll do so more digging into the manuals. There's got to be a way to do that, right?
I could put the router into gateway mode/passthrough as one of you suggested. But like I said router seems a little beefier with controls that I like..
Many thanks!
- FURRYe38Nov 22, 2022Guru - Experienced User
Use a wired PC and web browser to manage the Orbi system using it's web pages.
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
